jal69
Apr 05, 2020Aspirant
Wireless Backhaul Status
I have an RBK50 (1x RBR50; 1x RBS50). Firmware 2.5.1.8. Running Windows 10. I have a Spectrum Internet modem feeding the RBR50. I've seen posts where people have commented on what their back...
Apr 05, 2020Guru - Experienced User
Same thing in a different brower? IE11, FF or Opera?
Might try a factory reset on the RBR and RBS then try with syncing with just the one RBS. If you feel the system i working otherwise, you can run it as is...
jal69
Same thing in MS Edge.
Any idea what would "break" in the router or sat such that this would happen? Seems really odd.
