RebootFixesAll
Aug 12, 2018Follower
Wireless bridges in an Orbi setup
Hi
Can anyone help with the following,
I’ve recently invested in the Orbi Rbk50 for my home
i have a Asus Rt N66U router setup as a wireless bridge,
The Orbi router and N66U are in t...
Aug 13, 2018Guru - Experienced User
One user not too long ago mentioned that he was having problems with his ASUS wireless bridged. We did a few things however nothing seemed to work until he did a factory reset on the ASUS bridges and then set up up again from scratch...
Other things to try:
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only.
