jonasperman
Aug 03, 2022Aspirant
Wireless devices disconnect from RBR20
Hi, my hardware warranty ran out in late april so this is hopeful attempt of getting my problem solved. Many other similar posts are older so i need to bump the topic, hoping it is picked up by skill...
steele32701
Aug 04, 2022Aspirant
If possible, make sure that the different bands on your WiFi network are using the same name.
For example, make sure that you don’t have a network_name-2G network and a network_name-5G network.
On some products, particularly older WiFi extenders, you might not be able to avoid having different names for the different WiFi bands.
jonasperman
Aug 05, 2022Aspirant
Hi, thanks for the reply and trying to help out. AFAIK on the Orbi, you just give the SSID one name which is used for the two bands.
