jonasperman
Aug 03, 2022Aspirant
Wireless devices disconnect from RBR20
Hi, my hardware warranty ran out in late april so this is hopeful attempt of getting my problem solved. Many other similar posts are older so i need to bump the topic, hoping it is picked up by skill...
KevinLiT
Aug 05, 2022NETGEAR Moderator
Hello jonasperman,
Welcome to the NETGEAR Community!
I understand that you are experiencing intermittent network connectivity. This can be caused by having more than one router on a network processing routing protocol. To fix this please change your RBR20 from router mode to AP mode.
For instructions on how to change your RBR20 from router mode to AP mode please navigate to the like below:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Best,
Kevin
Community Team
jonasperman
Aug 06, 2022Aspirant
Ok thanks for chiming in! I will try. I have done this in earlier attempts but can try again. It did not help before and it also meant I lost a lot of the functionality of Orbi. But stable internet is most important.
I do not have multiple routers on my network AFAIK but I am in a bit of a pickle as fiber comes from one provider and the internet connectivity from another. That is the most common setup in Sweden, the physical network is open and multiple service providers can offer me internet, TV, telephony etc. This however means that two providers are involved to get me internet and not easy to get a clear answer...
- KevinLiTAug 08, 2022NETGEAR Moderator
Hello jonasperman,
Thank you for your reply!
I am sorry to hear that you are still experiencing this issue.
Please PM the following information so I can endorse you to our support team:
Name:
Email:
Phone Number:
Device Model:
Firmware:
Serial Number:
Preferred time to be contacted:
App version:
Please provide this information as soon as possible!
I look forward to hearing from you!
Best,
Kevin
Community Team
- jonaspermanAug 09, 2022Aspirant
Hi and thank you so much for this, i will PM you. It is such a pesky problem and i am so very pleased with my home Orbi setup, it is just up, all the time. I am optimistic about a solution to stable wifi/internet but i have not suceeded on my own even as a self proclaimed network just-level-below-expert... J
