wzaporozan
Jan 01, 2024Aspirant
Wireless devices Do not have internet service but show as connected to Orbi RBR50
My Orbi RBR50 (v2.7.4.24) appears to be functioning properly but none of my wireless devices have an internet connection. I can see all the devices in the connected devices list. I have reset everyt...
CrimpOn
Jan 01, 2024Guru - Experienced User
Do you use the Orbi 'app' or the web interface to administer this system?
When devices 'connect' and are assigned IP addresses but cannot get internet access, this can be a sign that Access Control has been enabled on the system (either on purpose or by accident).
Does the app Device Manager show a green slider under Allow Access for every device?
Does the web Attached Devices page show each device as "Allowed" rather than "Blocked"?
Does this system have Smart Parental Controls enabled?
p.s. Although Netgear has not set the Firmware Update feature to detect it, there is newer firmware for the RBR50, v2.7.5.4.https://kb.netgear.com/000065539/RBR50-RBS50-Firmware-Version-2-7-5-4 If you want to, this firmware can be downloaded and manually installed on the satellites and router:
I doubt very much that this situation is caused by the firmware release, but one of the first things people always recommend is, "update to the latest firmware". Your choice.
- wzaporozanJan 01, 2024Aspirant
I do have Access Control enabled and all devices are allowed.
Smart Parental Control is not enabled.
Thanks for the firmware update link. I will apply those.
- wzaporozanJan 02, 2024Aspirant
Today my router decided to show its hand. In Access Control, the devices had been showing 'Allowed'. Today a number of devices are showing 'Blocked'. I am unable to change them to 'Allowed'. I have turned Access Control off. Why has my router decided to lose its mind? I'll do a search first but looks like I will need to start a new thread.
- CrimpOnJan 02, 2024Guru - Experienced User
My experience has been that the tables in Access Control can be edited only when Access Control is enabled. When Access Control is not enabled, the user cannot change anything in:
- Currently Attached Devices (Blocked to Allowed)
- Allowed Devices that are not currently attached (remove from the table completely)
- Block Devices that are not currently attached (remove from table completely)
People who have Apple devices often find the "not attached" tables clogged with pseudo MAC addresses that Apple devices created and will never use again.
So, I "enable", do my edits, then "un-enable" and hit Apply. (Then come back and double check that Access Control is not enabled.)
