Ianfgraphics
Mar 08, 2021Aspirant
Wireless Half the Speed of Console
I just bought the Orbi Mesh system after bad luck with the TP Link DecoM9Plus. I have Century Link internet with 100mbps down and 10 up. After setting them up the SpeedTest on the app shows 100 and 10...
Mar 08, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- IanfgraphicsMar 09, 2021Aspirant
Firmware is 2.7.2.104
The modem I have is an Actiontec C3000A
The Orbis are about 20 feet away. I have the main in one corner of the house in the basement and the satellite in the middle of the house main level.
With basement its about 2000 sqft.
I have enabled BeamForming MIMO and WMM
I have disabled all except the coexistence I will try that.
- FURRYe38Mar 09, 2021Guru - Experienced User
Your modem has a built in router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- IanfgraphicsMar 09, 2021Aspirant
Ugh it took me 3 hours to get it to do that correctly with my old one. I guess Ill be spending the day doing that tomorrow lol. So I have set everything up based off of the thread that was shared and I am still getting about 60 down on my mobile phone. Laptop is better but I am also infront of the main Orbi
