Ianfgraphics
Mar 09, 2021Aspirant
Wireless Half the Speed of Console
I just bought the Orbi Mesh system after bad luck with the TP Link DecoM9Plus. I have Century Link internet with 100mbps down and 10 up. After setting them up the SpeedTest on the app shows 100 and 10...
Mar 10, 2021Guru - Experienced User
Your modem has a built in router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Ianfgraphics
Mar 10, 2021Aspirant
Ugh it took me 3 hours to get it to do that correctly with my old one. I guess Ill be spending the day doing that tomorrow lol. So I have set everything up based off of the thread that was shared and I am still getting about 60 down on my mobile phone. Laptop is better but I am also infront of the main Orbi
