mom24
Aug 20, 2020Aspirant
wireless on RBR50 connected to FIos ONT not working properly
Just had Verizon Fios installed 5 days ago. We have a ONTbox with cable connected to Orbi RBR50. The internet was going in and out, so I had verizon reset the network for us. Smart TV connected by...
Aug 20, 2020Guru - Experienced User
What FW version is currently loaded on the orbi system?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
mom24 wrote:Just had Verizon Fios installed 5 days ago. We have a ONTbox with cable connected to Orbi RBR50. The internet was going in and out, so I had verizon reset the network for us. Smart TV connected by ethernet is stable now. 21 wireless out of 38 devices are connected by wifi. Most of our smart Kasa light switches are not connecting, 2 out of 3 ecobee thermostats are not connecting, some alexas are not connecting and a smart tv. Verizon is telling me the wifi on Orbi isn't working well. I've tried calling Netgear customer service many times now, only to have call dropped after about 1 hour of waiting each time. pls help.
