jngIII
May 05, 2019Aspirant
Wireless performance
I just changed internet service providers, and since I did, my streaming apps - Hulu live, Netflix, prime video, pandora, etc. - no longer work. In communicating with both Hulu and my internet service...
SW_
May 05, 2019Prodigy
Is Orbi setup as Router or AP Mode?
Mine is setup in AP mode and I have not run into issue with streaming from Synology NAS or streaming from Netflix/Hulu/etc.,
AlbertOrbi
Thank you. I am using router mode (default). Would like to know by changing it to AP mode, do I need another router to be placed at the upfront position of the system layout.
I didn’t change the mode cause I don’t have another router apart from the Orbi.
- SW_May 05, 2019Prodigy
AlbertOrbi , your ISP box might act as both a modem and a router. Can you provide the brand and model number for the ISP box that Orbi is connected to?
- AlbertOrbiMay 06, 2019AspirantSW_, I think my modem is a tailor made one from the service provider, not one in the market. Anyway, I believe this is a pure modem.
- michaelkenwardMay 06, 2019Guru - Experienced User
AlbertOrbi wrote:
SW_, I think my modem is a tailor made one from the service provider, not one in the market.Possible, but I have yet to encounter an ISP that makes its own equipment. They usually get a hardware maker to tailor one of its models for its needs. For example, Netgear makes devices for a bunch of ISPs.
AlbertOrbi wrote:
Anyway, I believe this is a pure modem.I would not make any assumptions. Most ISPs also supply modem/router combinations.
Does your device do wifi and/or wired Ethernet? Does it have a bunch of ports on the back where you can connect other stuff?
