jngIII
May 05, 2019Aspirant
Wireless performance
I just changed internet service providers, and since I did, my streaming apps - Hulu live, Netflix, prime video, pandora, etc. - no longer work. In communicating with both Hulu and my internet service...
michaelkenward
May 06, 2019Guru - Experienced User
jngIII wrote:
I just changed internet service providers....
When you do this, you can't simply carry on as before. You need to get the equipment on your network to forget its misspent past with the old Internet service.
This usually means resetting things like modems and routers and connecting them to the new ISP from scratch.
If the ISP used its own equipment, that does not tell us anything about your own hardware.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
Maybe you have done all this. It isn't clear from your message.
