jngIII
May 05, 2019Aspirant
Wireless performance
I just changed internet service providers, and since I did, my streaming apps - Hulu live, Netflix, prime video, pandora, etc. - no longer work. In communicating with both Hulu and my internet service...
SW_
May 05, 2019Prodigy
AlbertOrbi , your ISP box might act as both a modem and a router. Can you provide the brand and model number for the ISP box that Orbi is connected to?
AlbertOrbi
May 06, 2019Aspirant
SW_, I think my modem is a tailor made one from the service provider, not one in the market. Anyway, I believe this is a pure modem.
- michaelkenwardMay 06, 2019Guru - Experienced User
AlbertOrbi wrote:
SW_, I think my modem is a tailor made one from the service provider, not one in the market.Possible, but I have yet to encounter an ISP that makes its own equipment. They usually get a hardware maker to tailor one of its models for its needs. For example, Netgear makes devices for a bunch of ISPs.
AlbertOrbi wrote:
Anyway, I believe this is a pure modem.I would not make any assumptions. Most ISPs also supply modem/router combinations.
Does your device do wifi and/or wired Ethernet? Does it have a bunch of ports on the back where you can connect other stuff?
- AlbertOrbiMay 06, 2019AspirantYes. The modem got 4 lan port at back for devices.
It’s a Huawei made for the service provider.
Do you think it’s a router/modem?- michaelkenwardMay 06, 2019Guru - Experienced User
AlbertOrbi wrote:
Do you think it’s a router/modem?Almost certainly.
