jngIII
May 05, 2019Aspirant
Wireless performance
I just changed internet service providers, and since I did, my streaming apps - Hulu live, Netflix, prime video, pandora, etc. - no longer work. In communicating with both Hulu and my internet service...
AlbertOrbi
May 06, 2019Aspirant
Thanks for help. It looks that I need to fix some more settings before a smooth streaming. Will try but this trouble is really unexpected before I decide to replace my router set with Orbi.
I have been using 2 AirPort Extremes before with exactly the same set up without any problem at all.
It is unfortunate that one unit has broken down and AirPort Extreme is discontinued. Sad.
May 06, 2019Guru - Experienced User
The change in upstream router should help get the system running well. Keep us posted.
