NewGeek's avatar
NewGeek
Wireless Printer connection sharing across RBK30 router and Satellite.
Hello All,   I have a Orbi RBK30 running with one main unit and one Satellite. About 10 devices using the system with some connected main router and other to Satellite. No performance issues for th...
  • NewGeek's avatar
    NewGeek
    Jul 05, 2019
    Hello all,
    RIP does not make a difference. Finally got some time and ran a low level network scan.  Found packets getting lost between router and satellite.
    Tired full power down and other scenario. Finally gave up and factory reset with backup.
    Restored from backup and then upgraded to today's latest patch. RBR40 2.3.5.30 and RBW30 / V2.3.5.6. Full power down and generated new password for Satellite and Router communication.
    Added device one by one.
    Ping works, Printers work, Network scan is clean. All Device on DHCP.
    Access control on with "Newdevice addition."
    Will let things stabalize and then change access control to "Block all new device.".
    Fingers crossed.
    Thanks for all you help and assistance.
