TylerW99
Sep 24, 2020Aspirant
wireless speed from att fiber router
I recently upgraded to ATT fiber internet into my home. The ATT router also broadcasts wireless, but I prefer to manage everything through Orbi so I have run a cat5 cable directly from the att modem...
Mstrbig
Sep 25, 2020Master
TylerW99 wrote:When I connect my iphone to the ATT wireless network, I get download speeds of 480-500 Mbps. But when I connect to the wireless network coming off the Orbi the speed is 250-300 Mbps. It is connected with 5G and WPA2-PSK security is enabled. I don't understand why the drop off..... Is there something in the configuration I'm missing? Could it be that the LAN output from the ATT Modem (BGW210-700) is significantly slower than the wireless (seems unlikely) ? Thoughts? Thanks in advance
If you used a cat5 cable change it at least cat5e. You may also be getting interference because of 2 WIFI networks in close poximity.
- TylerW99Sep 25, 2020Aspirant
Sorry - that was a typo - it is cat6. After a little research it seems I either have to put the ATT box in passthrough or my set my Orbi as AP to avoid double NAT. Not sure the pros/cons of each approach. I am using the ATT phone service as well, so not sure if that will work in passthrough.
- FURRYe38Sep 25, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode- TylerW99Sep 25, 2020Aspirant
Thank you for the reply. Can you highlite the pro/s cons of the router passthrough approach vs. the Orbi AP approach. The later seems simpler, but will it be less performant or less secure? Thank you
