Noisenet's avatar
Aug 15, 2019
Wireless Speed is Abysmal!
When I check my internet speed while connected wirelessly (5Ghz) I'm consistently getting between 6.9 Mbps. When I switch to a wired connection (through the same Orbi router) my speed jumps to 115 Mb...
  • FURRYe38's avatar
    Aug 15, 2019
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Yes you can factory reset the RBR and setup from scratch. You might do this first, with the RBR. Leave the RBS OFF. Setup from scratch and then test both wired and wireless speeds. Don't enable any Traffic Meter, QoS, Access controls like Armor or Circle. Just speed test with the RBR.
    Noisenet wrote:
    When I check my internet speed while connected wirelessly (5Ghz) I'm consistently getting between 6.9 Mbps. When I switch to a wired connection (through the same Orbi router) my speed jumps to 115 Mbps. I just rebooted the router, because this happens VERY frequently and now, even on a fresh reboot, this is still the case. So I updated to Router Firmware Version V2.3.5.30 which is showing as the current version.
    Checking wireless speeds on both a late 2015 iMac and a brand new 2019 Macbook Pro. Bogth computers are within 10 feet of the Router (not the satellite) and connected via 5g according to the Router's connected devices page.
    Is there some way to maybe reset to factory settings in case something's gotten changed?
