timmx3
Jan 07, 2018Aspirant
Wireless speed loss: what's normal?
I would like to know more about what to expect from speed loss to wireless devices. On the Orbi admin, speed tests for download run between 50-60 mbps, but the best I can test from a wireless device ...
DarrenM
Jan 09, 2018Sr. NETGEAR Moderator
Have you tried to enable beamforming and mumimo? Also have you adjusted the wireless channels on the router?
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
timmx3
Jan 12, 2018Aspirant
Yes, I have now enabled both beamforming and MUMI and has improved dramatically. I need to check wireless channels next. What is the best practice for channels for router+orbiAccessPoint+orbisatellite?
