ML2003
May 01, 2019Aspirant
Wireless speed vs Router connectivity color?
Hi all,
My first post. I just bought a RBK 23 (1 router and 2 satellites) and connected to a Spectrum modem. My internet speed is 400/400 through spectrum. I have the router in the office at 1en...
ML2003
Firmware is the latest- I check last night.
Will get the modum model # and manufacturer when I'm home later.
System appears to be working well. Kitchen speeds are great, upstairs speeds are ok. What is strange is when I'm in same room as router, before turning off daisy chain speeds were 400 mbps as expected, now 150-200 mbps. Not a big problem just strange.
Channels on auto. Will change channels and enable beamforming when home.
What is RBS?
Thanks
May 01, 2019Guru - Experienced User
RBS is the model nomenclature for the satelites. RBR is the router base.
I would enjoy the system. :smileywink:
