FishMacaroni
Mar 27, 2020Follower
Wireless VLAN and / or Bridge setup
Ok, I'm sorry to sound like a noob but I'm a noob. Please don't hurt me. I'm trying to run a low budget smart home and I've got two Orbi AC2200 systems comprised of the following. 2 RBR20, 2 RBW...
michaelkenward
Mar 28, 2020Guru - Experienced User
FishMacaroni wrote:
Please don't hammer me too hard, and thank you for your help.
You have my sympathy, but I have not much idea of what you really want to do.
I like to think simple, but you have complicated that approach.
This bit flashes warning lights:
FishMacaroni wrote:
..I've got two Orbi AC2200 systems comprised of the following. 2 RBR20, 2 RBW30, and 1 RBS40
Bad idea. Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
I'm afraid I don't get the specific reasons that you have presented. You seem to have come up with a solution – your idea what to do, with all that stuff about Wireless VLANs and Bridge setup – before you have addressed the simple question, what do you want to do?
FishMacaroni wrote:
I think VLAN's would be optimal....
I assume that you reached that conclusion because you read something somewhere. It looks a bit complicated to me.
My first move would be to put aside one of those Orbi routers and see if I can get what I need with all of those satellites. You can use then all with whichever router you decide to deploy.
FishMacaroni wrote:I'm afraid that won't do much to help the network (but it could certainly take some of the strain off of the satellite that is feeding roughly 40-50 devices at any given time).
Not sure what you mean by strain. Did your research take in this?
How many devices can my Orbi system support? | Answer | NETGEAR Support
I wonder if you are overthinking this? Start simple and add complexity when you hit a problem.
