AustinBike
Apr 26, 2018Star
With 2.1.4.10, Orbi does not know devices
I have roughly 37 devices on my network.
When I check the orbi console it tells me 34 or 35 devices. Then when I click on that icon I see ~19-20 devcies listed. Then I refresh the console an...
Jeremyinsf
Apr 28, 2018Apprentice
Actually when I compare the list to what's happening with DHCP messages etc, it does seem what is connected was accurate as of the moment the list was generated.
I didn't use to have disconnect problems but I do now. It's mainly noticed when I'm trying to use my Samsung S8 as a remote to my Harmony Hubs. But I do also see an Iphone on the network cut in and out as well.
The hardware and concepts behind Orbi are great but unfortunately, they really can't seem to figure this stuff out over on the engineering side. We should be moving forward with features, not spending six months on these 'basic' items such as general connectivity etc.
tsig
Apr 28, 2018Luminary
It's flaky. I am looking at my video doorbell as I type and Orbi does not show it as a connected device. It works though so I don't really care.
- Jcsmith760Apr 28, 2018TutorI’m having the same problem after installing 2.1.4.10 and resetting to factory default. Although devices are connected and working properly, some devices are not showing up in Netgear tools as connected. This isn’t a major problem, however Netgear needs to fix in the next firmware update. I need to know what devices are connected for security and troubleshooting reasons.
