Stan1717
Mar 11, 2021Aspirant
Wiz bulbs, plug'n'play
To the group, For some unknown reason I cannot write in the model number of my dual-band Orbi mesh router with 2 satellites. It is an RBK43S-100NAS. I am trrying to connect a number of Wiz sm...
- Jun 22, 2021
Dear FURRYe38,
Again, thank you for your explicit instruction for trying to help me get my Wiz smart bulbs connected via my Orbi mesh router.
My request was back in March. I never could make the connection, so just used the lights as dumb bulbs. The reason for failure was that I could not keep my Pixel XL phone communicating with the Orbi at 2.4Ghz long enough to complete the set-up. Last Sunday, I made another attempt to set up 8 Wiz bulbs. This time, I added one more step to your instructions: in the Netgear Advanced Wireless Settings 5Ghz section I unchecked "Enable SSID Broadcast" as instructed; in addition, I unchecked "Enable WMM (Wi-Fi multimedia) settings". Disabling this second setting seemed to keep my Pixel phone in the 2.4Ghz band long enough to make the set-up.
It took a few tries, but I finally got all 8 bulbs registered and properly grouped. Everything is working properly now. As a bonus, my two little grand daughters danced to the changing colored lights in the "Party" mode.
BTW, the caution buriedf somewhere in the Wiz instructions that the bulbs might not work in metal fixtures, still makes no sense to me. BR30 bulbs are meant to be installed in recessed light fixtures. We all know these recessed cans are made of metal.
Again thank you.
Stan1717
Mar 14, 2021Aspirant
Dear FURRYe38,
Thank you for taking time and writing out those explicit instructions. I put off trying to apply your 12-step program to my plug'n'play problem until I had a block of time, like today, Sunday.
I followed your instructions and everything seemed to be working as you described, but I could not make the connection. I don't know how many times I made a run at this easy plug'n'play application. At one point the Wiz program found my four bulbs and I could see lots of options for them. Great! But the program had no control over them - none, zero. I uninstalled the app and reinstalled it.
I think the problem is that the Orbi reverts back to 5Ghz too quickly - or seems to revert. I tried setting it to 25% power, and that may have helped. (But my computer was gasping for air to stay connected.) After a few hours, I gave up.
Oh, no, I just read another possible problem: the Wiz app says that the bulbs should not be surrounded by a metal fixture. Wait, what? I have 3 of these bulbs up on a track in metal fixtures. Isn't that a typical use? But one of the BR30 bulbs is in a wooden surround and the app could not find it either. Very frustrating.
Stan
CrimpOn
Mar 15, 2021Guru - Experienced User
Stan1717 wrote:At one point the Wiz program found my four bulbs and I could see lots of options for them. Great! But the program had no control over them - none, zero. I uninstalled the app and reinstalled it.
This "2.4G" issue only applies to connecting the IoT device to WiFi. Once any device has successfully connected to WiFi, then it no longer matters how the smartphone is connected. Many IoT devices can be controlled when the smartphone is not connected to the Orbi WiFi at all (through the "Cloud"). Perhaps start with only one bulb and see if the setup process can be completed?
Stan1717 wrote:Oh, no, I just read another possible problem: the Wiz app says that the bulbs should not be surrounded by a metal fixture. Wait, what? I have 3 of these bulbs up on a track in metal fixtures. Isn't that a typical use? But one of the BR30 bulbs is in a wooden surround and the app could not find it either. Very frustrating.
Metal is a barrier to WiFi signals. I have no idea where the WiFi antenna is located in these bulbs, but I would imagine they intend for the bulb not to be completely enclosed in metal.
You may not be alone in having problems (check the Amazon and Costco reviews).
