Stan1717
Mar 11, 2021Aspirant
Wiz bulbs, plug'n'play
To the group, For some unknown reason I cannot write in the model number of my dual-band Orbi mesh router with 2 satellites. It is an RBK43S-100NAS. I am trrying to connect a number of Wiz sm...
- Jun 22, 2021
Dear FURRYe38,
Again, thank you for your explicit instruction for trying to help me get my Wiz smart bulbs connected via my Orbi mesh router.
My request was back in March. I never could make the connection, so just used the lights as dumb bulbs. The reason for failure was that I could not keep my Pixel XL phone communicating with the Orbi at 2.4Ghz long enough to complete the set-up. Last Sunday, I made another attempt to set up 8 Wiz bulbs. This time, I added one more step to your instructions: in the Netgear Advanced Wireless Settings 5Ghz section I unchecked "Enable SSID Broadcast" as instructed; in addition, I unchecked "Enable WMM (Wi-Fi multimedia) settings". Disabling this second setting seemed to keep my Pixel phone in the 2.4Ghz band long enough to make the set-up.
It took a few tries, but I finally got all 8 bulbs registered and properly grouped. Everything is working properly now. As a bonus, my two little grand daughters danced to the changing colored lights in the "Party" mode.
BTW, the caution buriedf somewhere in the Wiz instructions that the bulbs might not work in metal fixtures, still makes no sense to me. BR30 bulbs are meant to be installed in recessed light fixtures. We all know these recessed cans are made of metal.
Again thank you.
Stan1717
Jun 22, 2021Aspirant
Dear FURRYe38,
Again thank you.
Jun 23, 2021Guru - Experienced User
Glad you got em working.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Enjoy. :smileywink:
