fargoboyle75
Dec 10, 2023Guide
Wlan access rejected : Incorrect security Orbi 40
I'm trying to connect a brand new Reoljnk camera via WiFi and having very little luck. In the logs it's showing wlan access rejected [WLAN access rejected: incorrect security] from MAC address 'x...
marshray48
Dec 10, 2023Aspirant
Since you've disabled the 5GHz band and attempted connection via 2.4GHz without success, it's worth double-checking the security settings on both the camera and the router. Ensure that the security protocols (e.g., WPA2) and the password match on both devices. Confirm that the camera is using the correct encryption method.
fargoboyle75
Dec 10, 2023Guide
There's not much to check the camera side, it scans a QR code of the SSID and password then 'should' configure it to setup and connect. The details are correct (tested to be sure on another device). I've even tried selecting both WPA2 and WPA created a password and tried that no joy. I must admit I'm not exactly a novice but by no means an expert in this area.
I have 2 other Reolink cameras, older models and they connected when they were setup in the past.
