Tomy159
Oct 02, 2019Follower
Wmware not working on bribge mode.
I'm sorry if that stupit question. I'm new in netgear products. I just swap from Asus read many reviews that orbi system is best. I setup yesterday night. Not sure if was easy but is done. Problem ...
Pummelchen
Oct 03, 2019Tutor
Bridge mode is transparent if you use an external dedicated IP for your VM, otherwise use NAT with port forwarding if you run a server in your VM. Just ensure you set 10.0.0.2 as your gateway inside the VM for NAT.
I run a website forum on my notebook > Debian VM > NAT > Windows Host > Orbi > Vofadone Router .. and it works great !
