ykcharrier
Jun 24, 2019Aspirant
WNDR4300 Connection is not private, certificate authority invalid
We randomly get the error message "Connection not private" when trying to use the internet through the Orbi network. I can switch to my 2.4ghz access point that is wirelessly connected to the Orbi sy...
ykcharrier
This is in regards to the Orbi system; it only happens when trying to connect to the internet while logged into Orbi. It occurs in all browsers. It occurs on all operating system: Windows, Android, and FireOS.
Firmware V2.3.1.58
Netgear modem D2200D
Jun 24, 2019Guru - Experienced User
Your modem already has a router built in:https://www.netgear.com/service-providers/products/telco/gateways/d2200d.aspx
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- ykcharrierJun 24, 2019Aspirant
Thank you for your help. I'll try this when it acts up again.
It's starting working again now without any changes. This equipment is very, very unreliable.
- FURRYe38Jun 24, 2019Guru - Experienced User
It's not Orbi, it's the interaction of your modem/router with the Orbi. Having two routers on the same line is mostly the instability. Please configure the modem for bridge mode or try one of the other suggestions. This will fix this issue.
