Joboo7777
May 16, 2021Apprentice
Woke up to a reset ORBI RBK50 system
Hello Folks,
I've had my RBK50 system for a few years now. This morning I woke up with no internet. After doing some troubleshooting I noticed that my Orbi system was broadcasting the standard "Orbixx" SSID which tells me the system may have been reset during the night. I suspect my system updated to 2.7.2.104. I honestly dont recall what version I was on prior. Thinking maybe 2.6.x.x???? Anyway, I basically have to set up my system from scratch. I dont run many customizations so it was not too big a deal. However, I'm trying to figure out the root cause. Is there any way to tell if the system did update recently?
Joboo7777 wrote:Is there any way to tell if the system did update recently?
When I telnet into my Orbi, there is a parameter that corresponds with when it last updated firmware (I believe. I did not record on the calendar at the time.) Telnet into the Orbi router and type the command nvram show | grep update
Here is my output. Notice the highlighted line:
root@RBR50:/# nvram show | grep update
update_agreement=1
update_ddns_time=0
last_auto_upgrade_url=https://http.fw.updates1.netgear.com/rbr50/default
sysDNSProviderlist=www/var/dynupdate.no-ip.com
openvpn_cert_update=0
update_ddns_ipaddr=0
fw_download_url=https://http.fw.updates1.netgear.com/rbs40v/V2.7/ww
base_upgrade_url=https://http.fw.updates1.netgear.com/rbr50/default
detect_update=08563774797
update_time=2021_4.20_23:10:36
update_ddns_format_time=0
update_tag=20
auto_update=1 - FURRYe38Guru - Experienced User
Save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
