OrbiNoob
Apr 27, 2019Follower
Wol help
I set up my orbi rbr20 as a wired access point and connected my PC via ethernet to the orbi. I can't get wol to work in this configuration. It was working when I had the orbi setup in router mode but ...
Apr 29, 2019Guru - Experienced User
You would need to probably set the Orbi back to Router mode or configure WakeOnLan on your main host router while the Orbi is in AP mode.
OrbiNoob wrote:
I set up my orbi rbr20 as a wired access point and connected my PC via ethernet to the orbi. I can't get wol to work in this configuration. It was working when I had the orbi setup in router mode but for other reasons I needed to change it to access point mode. Is it possible to get wol working as I have it setup now?
