ffwill22
Nov 06, 2019Guide
Won’t turn on
Device just stopped working. Three weeks after warranty expired. Please help
CrimpOn
Nov 06, 2019Guru - Experienced User
Is it correct to assume that you have (a) tested the electrical outlet with some other device that is know to work (light, radio, etc.), and (b) that you have swapped the power supply between the router and satellite?
- ffwill22Nov 06, 2019GuideA yes I tried the router in another outlet that works. As for the satellite I turned it off. Thinking I would turn it on if I could get the router up and running
- CrimpOnNov 06, 2019Guru - Experienced User
Great, verified "Electric Outlet Good." Next step, Power Supply.
(I should have asked, "Does the tiny Power LED on the back show Green, Orange, Red, or nothing?")
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
- ffwill22Nov 06, 2019GuideNo light at all
