crmark
May 19, 2020Aspirant
Won't connect to satellites
RBR40 with 2 satellites distributed throughout house. Devices used to automatically connect to nearest satellite or router. Now all devices are always connected to router as shown in Orbi app network ...
crmark
Thanks for the quick response!
Your suggestion worked: I'm able to see devices connected to the router and the satellites when viewed on the web interface vs. the Orbi app.
V2.3.5.32 is my current firmware.
Thanks
Thanks
CrimpOn
May 19, 2020Guru - Experienced User
It is probably a reflection on me being a crusty old guy, but the "app" just doesn't do much for me.
Release notes for the latest firmware, 2.5.1.16 claim it improves the device display. Go to Support and enter RBR40. Then select Downloads.
There is quite a controversy over whether doing a manual firmware update is a good idea.
- crmarkMay 19, 2020AspirantThanks CrimpOn I'll give it a try. I doubt if you're as crusty/old as I am!
Curtis- FURRYe38May 20, 2020Guru - Experienced User
Also be aware that it's up to the wifi devices them selves to pick and choose which signal to connect too.
If you reboot just the RBR alone leaving the RBS online, your devices should migrate to the RBS signal.
Curtis
