Aerofan81
Feb 13, 2023Star
Work VPN Being Throttled
Currently Using Netgear Orbi RBR50v2, Firmware V2.7.4.24 on a home network. I use a VPN for work and when I'm directly connected to my modem, I'm able to pull 170+ on the download when connected to ...
- Feb 14, 2023
Big-IP Edge Client is my VPN, but I don't think that is what is throttling my connection. When I connect direct to my modem (ethernet connection) and use my VPN, I get over 150MB/s down. When I'm on the Orbi, I'm getting 8.86 down and 8.86 up.
michaelkenward
Feb 14, 2023Guru - Experienced User
Aerofan81 wrote:
Anyone know why the Orbi is throttling my VPN connection?
Which VPN? Maybe that is throttling your connection.
Anything that forces your router to work hard on signal processing – parental controls, QoS and maybe VPN – can slow things down.
Aerofan81
Feb 14, 2023Star
- michaelkenwardFeb 14, 2023Guru - Experienced User
What is that modem?
- Aerofan81Feb 14, 2023Star
Xfinity XB7 modem/gateway
Aha. The VPN may be only half of your problem.
The modem/gateway is a router. So you are adding router to router. Bad idea.
What is Double NAT? | Answer | NETGEAR Support
Your VPN has to grapple with two routers that are trying to direct the traffic on your network.
There are a few options available for you to try.
The simplest might be to use the XB7 in modem only (bridge) mode.
?XB7 in Bridge Mode? | Xfinity Community Forum
Another simple solution would be to use the RBR50v2 in AP (access point) mode, but then you hit this:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
This might also help:
How to fix issues with Double NAT | Answer | NETGEAR Support
