Aerofan81
Feb 13, 2023Star
Work VPN Being Throttled
Currently Using Netgear Orbi RBR50v2, Firmware V2.7.4.24 on a home network. I use a VPN for work and when I'm directly connected to my modem, I'm able to pull 170+ on the download when connected to ...
- Feb 14, 2023
Big-IP Edge Client is my VPN, but I don't think that is what is throttling my connection. When I connect direct to my modem (ethernet connection) and use my VPN, I get over 150MB/s down. When I'm on the Orbi, I'm getting 8.86 down and 8.86 up.
Aerofan81
Feb 14, 2023Star
Xfinity XB7 modem/gateway
michaelkenward
Feb 14, 2023Guru - Experienced User
Aha. The VPN may be only half of your problem.
The modem/gateway is a router. So you are adding router to router. Bad idea.
What is Double NAT? | Answer | NETGEAR Support
Your VPN has to grapple with two routers that are trying to direct the traffic on your network.
There are a few options available for you to try.
The simplest might be to use the XB7 in modem only (bridge) mode.
?XB7 in Bridge Mode? | Xfinity Community Forum
Another simple solution would be to use the RBR50v2 in AP (access point) mode, but then you hit this:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
This might also help:
How to fix issues with Double NAT | Answer | NETGEAR Support
- Aerofan81Feb 14, 2023Star
If this were your setup, what would you do?
- michaelkenwardFeb 14, 2023Guru - Experienced User
Good question. I don't know what you do on your network, but I like simple, so I would go for bridge mode.
But I know that there are network nerds here who have their own ideas for complicated stuff that requires scary brain surgery on the router and its settings.
Try bridge mode and see if it mends the VPN. If so, check that it hasn't broken anything else that matters.
Thank you very much for your advice and assistance. I was thinking bridge mode as well.
