Aerofan81
Feb 13, 2023Star
Work VPN Being Throttled
Currently Using Netgear Orbi RBR50v2, Firmware V2.7.4.24 on a home network. I use a VPN for work and when I'm directly connected to my modem, I'm able to pull 170+ on the download when connected to ...
- Feb 14, 2023
Big-IP Edge Client is my VPN, but I don't think that is what is throttling my connection. When I connect direct to my modem (ethernet connection) and use my VPN, I get over 150MB/s down. When I'm on the Orbi, I'm getting 8.86 down and 8.86 up.
Feb 15, 2023Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System?
