lancetb
Aug 31, 2018Follower
Worth switching from TP-Link AC3150 to Orbi RBK20W AC2200
I have a TP-Link AC3150 and was thinking of buying a RBK20W. My house is pretty small (1600 FT^2) and I live alone, so I don't need the extra satellite, but was thinking of buying the Orbi because it...
Aug 31, 2018Guru - Experienced User
I would check the specs on the RBK20 vs your TP-Link. See if the specs are about the same or better.
https://www.netgear.com/support/product/orbi.aspx
Depending upon placement and building materials a single router should cover your house hold for the size it is. 30 feet is recommended in between them to begin with depending upon building materials.
