gregerst
May 21, 2018Aspirant
Would you recommend Netgear ORBI?
Hello All,
We will be moving into a new home next week. The home has three levels and aprox 4000 sq ft so I am thinking a mesh system would be benificial specifically RBK53 from Costco. We also hav...
May 21, 2018Guru - Experienced User
Kind of defeats the design of a MESH wireless system having Smart Connect and intented single SSID name and PW.
avtella
May 21, 2018Prodigy
You can have mesh without band steering, I suppose band steering is ok for things like browsing the web but when you need bandwidth and it throws you down to 2.4Ghz it’s not ideal. I suppose they could keep it as it currently is at setup as that’s fine for most users but give an advanced option to disable band steering for more advanced users like Velop already does.
