gregerst
May 21, 2018Aspirant
Would you recommend Netgear ORBI?
Hello All,
We will be moving into a new home next week. The home has three levels and aprox 4000 sq ft so I am thinking a mesh system would be benificial specifically RBK53 from Costco. We also hav...
tucsontico
May 22, 2018Virtuoso
I've had an ORBI RBK50 system installed in my house for over a year. My home is single story and about 3000 sq ft with concrete block construction and a stucco exterior. I also have an 4 car attached garage/shop and an outdoor living space with pool automation. I estimate the entire area covered by the ORBI at >5000 sq ft. I've had very good luck with the ORBI system. That's not to say it has been trouble-free. The initial set-up requred a bit of hassle to find the "Goldilocks" spot for the satellite and each firmware update seems to require a factory reset.
I recommend you purchase the ORBI at Costco and test it in your environment. If it doesn't meet your needs–return it and move on to another system. However, if you follow most of the hints/tips in this community, e.g., don't put the satellites too close, deconflict the 2.4 gHz & 5 gHz channels, factory reset after firmeare updates and manually configure your system, you'll find you can have a very stable, powerful WiFi system. Good Luck!
- tsigMay 22, 2018Luminary
Yes I would. Mine has been rock solid reliable and I get my full internet speed everywhere in my house, yard and drive way.
- Dustin278May 22, 2018Apprentice
Yes - I have 4 total Orbi's. Bought the 3 pack from Costco and use a small RBS30 plug - I own a 3 leveI home nearly 5,000 sq ft. I have my Orbi in AP mode and have 1 Router + 3 Satellites (1 Router RBR50 on main level with 2 - RBS50 Satellite's on my upper level and my basement with 1 small plugin RBS30 in the garage) - probably overkill but has been great for me and covers my whole yard - no issues since the S8 bug was fixed many months ago.
