gregerst
May 21, 2018Aspirant
Would you recommend Netgear ORBI?
Hello All,
We will be moving into a new home next week. The home has three levels and aprox 4000 sq ft so I am thinking a mesh system would be benificial specifically RBK53 from Costco. We also hav...
gregerst
May 22, 2018Aspirant
I am glad to see the positive feedback from everyone so far. I will most likely follow the suggestions and get the kit from Costco, the fact that it's currently $70 off is definetly nice too. With Costco generous return policy I should have ample time to use it long enough to determine whether it is going to be suitable or not.
I haven't looked at the manual yet, does anybody know if it supports VLAN tagging?
- avtellaMay 22, 2018ProdigyIt does LAN side but not WAN VLAN. I assume it’s for CenturyLink?
- FURRYe38May 23, 2018Guru - Experienced User
What Mfr and model# ISP modem will your system be connected too?
Any network LAN switches in your system currently? If so, what is the Mfr and model#?
