jdorion
Aug 21, 2018Aspirant
Would your recommend ORBI RBK53
The RBK53 form Coscto fits my needs as well as my budget for a mesh wireless network. However, reading all the issues a lot of users have and are currently experiencing has made me stop and reevaluat...
Aug 21, 2018Guru - Experienced User
30 feet is recommended in between router and satllite(s) to begin with depending upon building materials for wireles back haul.
Depending upon size and lay out of home, you may only need just one satellite. Too small of a home, you don't need additional satellites. The router alone can cover a large are by itselt and you don't want over lapping wifi signals.
- jdorionAug 21, 2018Aspirant
It's about 1800 sq.ft, split entry. Internet comes in downdstairs in a corner. The bedroom downstairs which is on the opposite side of the current AP has spotty connection. The bedrooms upstairs which are are on the opposite side of the current AP have poor signal.
I currently have an older Asus router N66U (wireless disabled) and using an Ubiquiti AC Pro my main AP. Modem, router, and AP are on the lower level.
I've also thought about upgrading my router and getting two NETGEAR Nighthawk X6 AC2200 WiFi extenders. I'm still on the fence as to what my best option would be.
