jdorion
Aug 21, 2018Aspirant
Would your recommend ORBI RBK53
The RBK53 form Coscto fits my needs as well as my budget for a mesh wireless network. However, reading all the issues a lot of users have and are currently experiencing has made me stop and reevaluat...
Aug 21, 2018Guru - Experienced User
Are you using that stuff along with the Orbi?
That size of home should only need the Orbi router and just 1 satellite..maybe. Nothing else. Placement will be key.
jdorion
If I get the Orbi it will replace my Asus N66U router as well as the Ubiquiti AP. Are you thinking that 2 satillites would have a negative affect? I need to place one satellite in the room on the lower on the opposite side of where the router will be, due to the computer in there will utililize the Ethernet port on the satellite.
