chfrank
Jun 20, 2017Aspirant
WPA Key limitations ORBI wifi router
Is the number of active simultaneously connected devices connected to an Orbi router limited by the number of WPA keys it can support? Are the 50 streaming devices assumed to be streaming with encryp...
rhester72
Jun 20, 2017Virtuoso
chfrank wrote:Is the number of active simultaneously connected devices connected to an Orbi router limited by the number of WPA keys it can support? Are the 50 streaming devices assumed to be streaming with encrypted links? Is the 50 limit per Orbi unit? Where are the device limits documented?
Thank you,
Chris
What documentation have you seen that suggests there's a limit associated with keys?
Rodney
chfrank
I have run into this with other routers. I wanted to understand if Orbi had the same limitation or not. Other routers have a simultaneous key limitations
