Russ2020
Jun 29, 2020Aspirant
WPA3 and Wifi6 capable?
Before I buy a replacement router/mesh system I need to know whether it will support WPA3 and Wifi6. I was looking at the Netgear website and could not find specs for the Orbi Tri-Band Mesh WiFi Rou...
- Jun 29, 2020
I would recommend holding off on WPA3 on home routers. Until router mfrs can fully make both WPA2 and WPA3 work together. Current NG Orbi AX routers don't support mixed modes.
Jun 29, 2020Guru - Experienced User
The RBR20 series is not currently wpa3 capable. And they're not wifi 6 devices. You'd need to step up to the orbi devices that support it. this page lists all netgear's AX (wifi 6) devices.
