Russ2020
Jun 29, 2020Aspirant
WPA3 and Wifi6 capable?
Before I buy a replacement router/mesh system I need to know whether it will support WPA3 and Wifi6. I was looking at the Netgear website and could not find specs for the Orbi Tri-Band Mesh WiFi Rou...
- Jun 29, 2020
I would recommend holding off on WPA3 on home routers. Until router mfrs can fully make both WPA2 and WPA3 work together. Current NG Orbi AX routers don't support mixed modes.
Jun 29, 2020Guru - Experienced User
Russ2020
Jul 02, 2020Aspirant
Thanks for the advice. I'm not normally an early acceptor but I'm trying to help my family. I saw an article that implied that WPA3, accepted in 2018 according to the article, was a done deal. The article also talked about WiFi6 was fairly new and in development. I might have got this reversed but I thought I would check. I saw positive reviews of the Orbi Mesh system which I thought was interesting. I'm not thrilled about the price so from that point of view I might wait until other manufacturers come out with their products to see if there is a price adjustment.
