Russ2020's avatar
Russ2020
WPA3 and Wifi6 capable?
Before I buy a replacement router/mesh system I need to know whether it will support WPA3 and Wifi6.  I was looking at the Netgear website and could not find specs for the Orbi Tri-Band Mesh WiFi Rou...
  • FURRYe38's avatar
    Jun 29, 2020
    I would recommend holding off on WPA3 on home routers. Until router mfrs can fully make both WPA2 and WPA3 work together. Current NG Orbi AX routers don't support mixed modes.
