GWild
Jan 27, 2021Guide
WPS is ON all the time, and can't be disabled
Orbi RBS20/CBR40 System WiFi Monitor is showing the network as WPS enabled: so it seems it is susceptible to the WPS hacks out there. There is also no visible way to disable WPS within the Orbi L...
Jan 28, 2021Guru - Experienced User
Please visit and post about this over in the Orbi with Cable modem forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
GWild wrote:Orbi RBS20/CBR40 System
WiFi Monitor is showing the network as WPS enabled: so it seems it is susceptible to the WPS hacks out there. There is also no visible way to disable WPS within the Orbi Login controls.
Has anyone figured this out?
ps: the article people refer to in other threads says all three methods are used, so please don't contradict what Netgear by saying PIN mode isn't used. Sure, we can't enter or change the PIN, but the router seems to have the code to support it running 24/7 (the router will respond to a PIN request my WiFi tool is probing). And it's the WPS protocol that is hackable, not by the brute force method which Netgear says they defend against.
Ideas?
