jimbojames79
Apr 18, 2019Apprentice
WPS PIN
Hi, Where can I find the WPS PIN for my router? Thanks
SW_
Apr 18, 2019Prodigy
jimbojames79 Wrote:
Hi,
Thanks
Try this:
Replace 192.168.1.1 with your router IP address:
http://192.168.1.1/hidden_info.htm
You should see the "PIN Code" along with the rest of the secrets. Save a copy of that for future reference.
michaelkenward
Apr 19, 2019Guru - Experienced User
SW_ wrote:
jimbojames79 Wrote:
Hi,
Thanks
Try this:
Neat.
