Fourcats
Mar 10, 2020Aspirant
WPS process is in progress, please apply the changes later
This is actually an issue with the RBK22, but it wasn't a model that I could pick from in the list. I recently bought the RBK22 and I'm trying to make some security changes on the orbilogin.com w...
Mar 10, 2020Guru - Experienced User
Try a factory reset on the RBR and RBS and walk thru the setup wizard with a wired PC. Leave the RBS off for now. Make the changes you need to on the RBR after the setup wizard completes. When you done, add the RBS to the RBR.
Fourcats
Thanks! I will give that a try.
