cinek
Apr 06, 2018Apprentice
wtf is going on
new orbi issue. Satellite just restarted and not won't connect to the router. Purple light. I know bring it closer but why should I? I'm typing this on a laptop that's further away from the router th...
- Apr 28, 2018
done all that numerous times with no luck. We're basically back to the issues I had at the beginning where the internet on the satellite would drop and the ring would not even light up. Restarting it fixes the issue for a few hours.
I've honestly had enough and bought a ubiquity access point. Will run cables all round the skirtings but f*ck it. At least it'll work! bye netgear, never buying another piece of sh*t product from you again. Orbi going in the bin where it belongs
Apr 06, 2018Guru - Experienced User
What model Orbi system do you have?
How are the satellites placed? Distance from the router? Ft?
What is the Mfr and model# of the ISP modem the router is connected too? Any built in router here?
Need more information here. Others have set up there systems just fine.
cinek wrote:new orbi issue. Satellite just restarted and not won't connect to the router. Purple light. I know bring it closer but why should I? I'm typing this on a laptop that's further away from the router than the sattelite and it works just fine being connected to the router itself. So why for the flying fu*k can the satellite not connect? I'm on V2.1.2.18 and no new updates are available. This product is shockingly bad. Should be recalled
