cinek
Apr 06, 2018Apprentice
wtf is going on
new orbi issue. Satellite just restarted and not won't connect to the router. Purple light. I know bring it closer but why should I? I'm typing this on a laptop that's further away from the router th...
- Apr 28, 2018
done all that numerous times with no luck. We're basically back to the issues I had at the beginning where the internet on the satellite would drop and the ring would not even light up. Restarting it fixes the issue for a few hours.
I've honestly had enough and bought a ubiquity access point. Will run cables all round the skirtings but f*ck it. At least it'll work! bye netgear, never buying another piece of sh*t product from you again. Orbi going in the bin where it belongs
joknutsen
Apr 06, 2018Guide
I think I would update to the latest FW 2.1.3.4 and see if that made a difference. However, if this just all of a sudden happend I would think there is a HW error.
https://www.netgear.com/support/product/RBK50.aspx#download
good luck
cinek
Apr 27, 2018Apprentice
updated to 2.1.4.10 and satellite has gone twice now. Satellite is about 10-15m from the router. It's the RBK50 system
- FURRYe38Apr 27, 2018Guru - Experienced User
Power OFF the router and satellite. Then power ON the router first then satellite.
Try manual channel 1, 6 or 11 on 2.4Ghz and 48 on 5Ghz
Try placing 30-40 feet..
Diable MIMO, Daisy Chain and Fast Roaming
- cinekApr 28, 2018Apprentice
- FURRYe38Apr 28, 2018Guru - Experienced User
Might try to sell it on ebay or something.
Good Luck.
