SoCal2019
Feb 16, 2019Aspirant
www.####.com:80 and 401 Unauthorized error messages
My Orbi doesn't allow access to several common websites, like weather.com, espn.com, and many others.
First, I get the message 'Login to www.####.com: 80 and it asks for username and password. T...
- Feb 17, 2019
SoCal2019 wrote:
Thank you VERY much!
The ISP Modem/Router is what Spectrum provided me (without a manual): Sagemcom RAC2V1S.
Can you please tell me how to set the Orbi in AP mode? (I do not see any buttons for that, and I don't remember being asked what mode I wanted when I set it up.)
Again, THANK YOU!
Yes, Sagemcom RAC2V1S is a router and I think this is exactly what is causing your issues.
You can set Orbi in AP Mode by logging in to the web GUI from any computer by browsing to orbilogin.com, login using your admin password, then follow the following links to set Orbi to AP Mode and then click on Apply:
SoCal2019
Feb 17, 2019Aspirant
Again, THANK YOU!
ekhalil
Feb 17, 2019Master
Again, THANK YOU!
- SoCal2019Feb 17, 2019Aspirant
THAT'S IT - THANK YOU!!!
- ekhalilFeb 17, 2019Master
You welcome. Glad that this helped! :)
- randomousityFeb 17, 2019Luminary
If you actually want to use the Orbi's features (other than mesh wifi), you can also put your modem/router into bridge mode, and then change the Orbi to router mode. Basically, as long as you only have one router routing, and the other in bridge mode (Orbi calls this AP mode), you can use whichever one has more/better features, you like better, etc., and have the other one be transparent (which is what bridge/AP mode does) and not causing any interference.
