Bboy486
Apr 22, 2019Aspirant
WyzeCam and 5G incompatibility Orbi
I am getting constant drops on my wyze cam that is 5 ft from a satellite. Wyze support says it's because the orbi is connecting the 5g network. The asked me to use 2.4 but as far as I can tell Orbi do...
Jun 30, 2019Guru - Experienced User
This would indicate that these Cams have an issue the QoS and or WMM if encountering across more than one router model varient. Something the Camera Mfr should be looking into.
