Bboy486
Apr 22, 2019Aspirant
WyzeCam and 5G incompatibility Orbi
I am getting constant drops on my wyze cam that is 5 ft from a satellite. Wyze support says it's because the orbi is connecting the 5g network. The asked me to use 2.4 but as far as I can tell Orbi do...
Crazy_Canuck
Jul 01, 2019Aspirant
Thanks - QoS was not 'selected' on the Orbi configuration screens and I could not find anywhere to set address reservations. Thanks for the suggestions though
CrimpOn
Jul 02, 2019Guru - Experienced User
Do you administer the Orbi with the web interface or an "app"? Device IP assignments on the web interface are on the Advanced Tab->Setup->LAN Setup screen.
