Bboy486
Apr 22, 2019Aspirant
WyzeCam and 5G incompatibility Orbi
I am getting constant drops on my wyze cam that is 5 ft from a satellite. Wyze support says it's because the orbi is connecting the 5g network. The asked me to use 2.4 but as far as I can tell Orbi do...
Apr 23, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
hrachyap
Dec 01, 2019Aspirant
I had similar problem connecting Wyze Cam Pan to Orbi. It seems disabling 20/40 MHz Coexistence helped solve the problem.
Thanks!
